| Message |
So I roll in to work today, turn my 90 NA off, and the starter keeps going...even with the key out of the ignition. If I turn the ignition to "on" the engine starts right up and the starter STILL keeps running (don't even need to turn key to start). I finally disconnected the battery to get it to stop...hoping it will get me home today when I connect it back up. Any ideas for a true fix? I searched and only found 1 post that recommended starter relay...is this the blue one in the wheel well (I've replaced that before for NOT starting...) or on the starter? Or is my starter bad? I've had ZERO other issues with the car starting.. Thanks in advance! Tom P
